Need help with my balls!
George Andrease
05-06-2006 17:11:03
Now that I have everyone's attention...I'm completely rebuilding the Ross steering box on my 1940 model B. The ball bearings are corroded and pitted so I'd like to replace them, BUT they measure about .290 or so (hard to mike) which is close to 19/64"..an odd size. Has anyone done this before? Would a larger 5/16" (.312) ball work or just jam up when I try to assemble and adjust the unit? Thanks in advance! George
Ed (C-IL)
05-07-2006 20:06:34
 Re: Need help with my balls! in reply to George Andreasen, 05-06-2006 17:11:03
I just got done rebuilding a ross box on a C and I put 5/16" balls in it. Works fine.
BDT in Minnesota
05-07-2006 15:47:22
try the bearing supply outfits if agco can"t help...www.timkin.com would be a good place to start...that site should lead you to your nearest vendor who would be able to order the bearings for you..Use what belongs in the steering gear or you will be waisting your time...Bearing components can be called oblelete by a machinery company, but those same bearings may be used in other applications, and still be current items of the original bearing supplier...
George Andreasen
05-07-2006 19:59:48
 Re: Need help with my balls! in reply to BDT in Minnesota, 05-07-2006 15:47:22
FOUND 'EM! A company in Salem, Mass. carries every size ball bearing you can think of and will sell small quantities...so I'm set.
Spent today welding up the badly worn pin or "finger" than rides in the steering worm. Used a Dremel tool to grind the angles, reassembled and it works well with no slop or binding. Didn't have steering box grease, so I used 600 wt. oil (not a typo). Turns nice and easy, but I'll install the new balls for a first class job. Thanks everyone!
Kent of SW MO
05-07-2006 13:22:34
Have you contacted a AgcoAliis dealer to see if they can order the correct parts?
Kent
George Andreasen
05-06-2006 19:31:55
Thanks for all the input....I think I'll order some 5/16" and give it a try. There were shims still under the steering tube, yet there was a fair bit of end play..so if I had to I could add even more shims for more room. I'll post again whether it works or not..might help someone trying to do the same overhaul. Thanks again guys!
Dachshund
05-06-2006 19:03:26
Well - in my experience with British Motorcycles (which have loose-ball bearings in the old days), a worn and pitted bearing will be undersized in relation to what it is SUPPOSED to be. I'd go with the 5/16" if you can't find documentation of the proper size.
Henry M
05-06-2006 17:16:58
George
I wouldn't see where big balls would be a problem. Just couldn't resist.
kingmondo
05-06-2006 18:51:43
 Re: Need help with my balls! in reply to Henry M, 05-06-2006 17:16:58
Don`t know if this info is of any use to you but Ross did steering gear boxes on forklifts.
