B HYD. PRESS ?
FDBYRD
05-06-2006 05:29:21
ANYONE KNOW HOW MUCH PSI AN ALLIS B HYD. PUMP WILL MAKE?
steve(ill)
05-06-2006 18:33:25
 Re: B HYD. PRESS ? in reply to FDBYRD, 05-06-2006 05:29:21
the old tractors fromt he 1940-50 era put out 3200 psi and very little flow, maybe 1/2 gpm or so. takes a very small cylinder, about 3/4 to 1 inch diameter to lift small tools.---- after 1960 with the D series ALLIS went to a low pressure, higher flow system.--- the old system works o.k. as long as you dont need lots of volumn, like a log splitter.
old
05-06-2006 08:05:12
Well not sure if this is correct since it seems a little on the high side but the I-T books says something about 3100PSI and 1500 PSI. The lower number sounds more like what I would figure the pump would put out. If you have the I-T manual its paragraph 320
