wc gas tank
Charley Arms
05-05-2006 19:04:02
anybody know where i can find a gas tank for a wc 1942?
charley arms
05-13-2006 21:41:49
 Re: wc gas tank in reply to Charley Arms, 05-05-2006 19:04:02
just for info:
i solved the rust problem by making a longer pickup tube for the inlet fitting
i soldered a piece of tubing into the tank fitting raising the pickup 2 inches
i then added a trans magnet from an automatic transmission to attract what rus was left
i started by running a strong magnet around the tank and then flushing several times with fuel
pulled it today and went 317.69 274.50 204.99
i hope it keeps working
thanks for info anyway
Paul from MI
05-07-2006 06:49:20
If it 's not too bad, or actually leaking, you might try having it cleaned and plastic coated. I have had four or five done by a local radiator shop. Cost was about $60. My B tank was rusty & I cleaned it with some large gravel & a lot of shaking. Use some gas to help keep the gravel clean & abrasive. Getting it all out was a trick due to the shape of the filler neck, but I made an attachment for my shop vac that worked OK. Then I used a kit I got at our local auto parts to coat the tank. No problems after two years. Cost was about $25.
Good luck,
Paul
Joe M(GA)
05-06-2006 19:18:19
The WC and WD tanks are not the same. The fuel outlet is on the wrong side on a WD tank.
old
05-06-2006 12:03:56
Well if its the same as on the WD I have one
charley arms
05-06-2006 19:29:43
 Re: wc gas tank in reply to old, 05-06-2006 12:03:56
it really doesn't matter which side the outlet is on
what condition is your tank
mine has bad rust and pitting
email me at [email protected]
