Hydraulic capacity on WD45
rfdeere
05-05-2006 18:15:53
Howdy, I want to run a hydraulic hog trailer and I was wondering if my 45 has enough resevoir capacity to run this. It has two cylinders, approx. 2" bore by 8" stroke.
steve(ill)
05-06-2006 18:37:35
 Re: Hydraulic capacity on WD45 in reply to rfdeere, 05-05-2006 18:15:53
the common sump tractors are the little B-C-CA tractors. old ALLIS tractor have lots of pressure, 3200 psi, but very small volumn output. since the cylinders are only 2 inch dia and 8 inches long, it is very close to working. if you put an extra quart or two in the hydraulics it will probably work o.k.--- the idea of an extra tank is good, lot of guys do that. your cylinder is small enough it may work. i run one cylinder 2 x 8 on a B tractor.
souNdguy
05-06-2006 22:54:07
 Re: Hydraulic capacity on WD45 in reply to steve(ill), 05-06-2006 18:37:35
I'm pretty sure the g is common sump too.. more or less a b tranny case and no final drives.. etc..
soundguy
souNdguy
05-05-2006 21:38:31
According to my AC-11 I&T manual.. the wd and wd45 have a common sump tranny/diffy, and it holds 17 quarts. If the hyds are also common sump.. I'd guess that you have plenty of oil laying around to work with..
Soundguy
JMS/MN
05-06-2006 17:30:56
 Re: Hydraulic capacity on WD45 in reply to souNdguy, 05-05-2006 21:38:31
No. Hydraulic sump is not part of the tranny/rear end. Uses different oil as well. Op manual would show the capacity, which is not much, but another reservoir can be plumbed in.
souNdguy
05-06-2006 21:17:36
 Re: Hydraulic capacity on WD45 in reply to JMS/MN, 05-06-2006 17:30:56
I wonder why the service manual doesn't show a hyd capacity? It has capacities listed for the final drives, pto gearbox, diffy/tranny, and crankcase. Were hyds 'standard' on wd/45's?
Soundguy
Sid
05-06-2006 22:28:46
 Re: Hydraulic capacity on WD45 in reply to souNdguy, 05-06-2006 21:17:36
I have never seen a WD without a hydraulic pump. But according to my owners manual it was an option on the early WD. If I remember right the capacity is five quarts. According to some sales literature I have on the WD45 they list a remote cylinder as an option. Reading of that manual makes me think it was standard on the WD45. I do not know why they did not include hydraulic capacities but I have the same manual you refered to and I did not find it either.
