leaking power steering system
bob guthrie
05-04-2006 12:27:21
I have an old WD 45 that has a char lynn pump in the steering shaft that leaks. It also has an eaton pump mounted above the water pump, this also leaks. Does anyone out there in tractor land rebuild these things? These must have been added because there is no way to fill the reservoir on the eaton pump without removing the hood. If it was original wouldn't it have a hole in the hood for refilling the unit?
thanks/ new person on the forum
Dave Grubb
05-05-2006 12:59:10
 Re: leaking power steering system in reply to bob guthrie, 05-04-2006 12:27:21
These folks can supply you with parts. The torque generator unit is easy to reseal; however it is a timed unit. You must mark the shafts/housing sections. You must mark the internal gerotor parts.
