WD45 Puller
williamt
04-30-2006 17:32:34
I am building a 57wd45 puller,I would like to know what you think of engine combo.4 1/8 overbore,D17 cam,decked head,and valve job,not sure about pistons,flat top,or power crater.Any thougts.Any Virgina pullers out there on the coast around Gloucester.Not much pulling around here anymore.
allisd17d
05-06-2006 18:38:21
 Re: WD45 Puller in reply to williamt, 04-30-2006 17:32:34
Yea Up here at Tappahannock, Va. theres a pull in millers tavern on the 13th and one at james city county fair on june 24-25 i think.combo sounds good as long as it will run with no problems.shouldnt be any tho
northerndave
05-01-2006 14:18:39
it"s a flat head. only reason for cutting the head would be to true the surface. no compression gains to be had from the head. no combustion chamber there, combustion chamber for that engine is on the face of the piston (the power crater dished piston) the d-17 piston is the same diameter & still has the crater top for combustion but the pin location is lower which gives you some compression gains over the 45 piston. 7.25:1 rather than the original 6.45:1
