Hi Mike, Glad to see you got something put together for the front weights (also glad to see that my drawing got some use :)). I'd love to see any pictures you have. If you have taken any with a digital camera, email them to me and I will be glad to post them here for you. I'm sure others would be interested also. Alternatively, I'd be glad to lead you through posting them yourself, step-by-step if you wish. Regarding the engine side weights, installing just one side will do no harm at all. It will depend on the exact weight you have whether it can be installed on either side though. Most will tell you that both weights are the same. That's generally true but not always so. The early weights were different between the right and left side on the B. If you have one of the early weights without the chamfer, there can be an interference problem with the B steering linkage during a hard left turn. I have added a dedicated page to my website that shows the side weights and the chamfer I am talking about, as well as a drawing of the bushings that are used to mount them to the front support plate. When you bolt the weight to the torque tube, make sure your bolts are not too long. The tapped holes in the torque tube are through holes (not blind ones) and a long bolt can actually protrude enough to contact the flywheel and lock the engine up. I've also made other changes to my site, including a page for the wishbone weights. If you haven't visited there recently, you might be interested in checking it out by going to the front index page here. Rod
