WD oil filter mount
GWalker
04-29-2006 10:31:15
While replacing the pushrod cover and the oil filter mount gaskets on my '52 WD I made the tragic error of over-tightening the oil line fitting into the oil filter mount, cracking it. I was wondering if this oil filter mount is interchangable with any other AC models of that era? Thanks.
Rick Corder
04-30-2006 04:48:13
 Re: WD oil filter mount in reply to GWalker, 04-29-2006 10:31:15
The oil filter bases are the same on the B,C,CA,WC,WD,WD45 and the early D17's for sure. Hope this helps. Rick
old
04-29-2006 10:37:45
Should be the same as on the WC, WD, WD45 and maybe a few others. I would probably have one or two of them. I have 2 parts engines. One is a WD and the other is a WD45 engine. E-mail is open if you want info
