timing for allis 47 b
SAL BARTOLOTTI
04-29-2006 06:46:54
i have tried to install this distributor for 47 allis b that replaces the mag. I install it on the center mark of the flywheel start the tractor will not let me bring up to mid throttle to advance the weights in the distributor so i can set the timing!! Also for the life of me I can not find the right spot for the spring for the throttle rod everywhere that i install it seems like to much resistance back on the throttle!!1
can any body help
steve(ill)
04-29-2006 19:43:55
 Re: timing for allis 47 b in reply to SAL BARTOLOTTI, 04-29-2006 06:46:54
move the throttle rod at the carburetor with your finger and see if you can speed up the motor. if so, your spring is too tight.
sal bartolotti
04-29-2006 16:15:22
I was told that after installing the distributor at the fire mark and setting the rotor at 1 position on the cap to start the tractor and bring to mid throttle to advance the weights in the distributor to set the mar on the fire mark on the distributor but I am not able to bring the tractor to mid throttle to set the timing at the fire mark not sure what I AM DOING WRONG!!!!
jeffalex2
04-29-2006 14:28:15
I don't quite follow...why won't the tractor increase speed to advance the timing?
Rod (NH)
04-29-2006 09:43:17
Hi Sal,
I'm not sure what spring you are referring to. There is a governor spring at the governor and a link spring near the carburetor. The link spring is an anti-surge spring. It has very light tension and attaches to the upper manifold stud forward of the carburetor as well as to the throttle linkage near to where that attaches to the carburetor throttle plate shaft. Here's a picture showing how the link spring attaches:
third party image
You have to insert the long loop end up behind the exhaust manifold and hook it over that stud. That's a blind operation. Temporary removal of the carburetor will probably be necessary to easily install that spring. The spring opposes governor action to close the throttle. It is at maximum tension (which isn't very much) when the throttle plate is closed at idle position. It is totally relaxed with no tension at all at wide open throttle.
third party image Rod
