Another battery cable question
Jim- DR
04-27-2006 17:26:51
I have a heavy duty battery cable for my WD but the clamp on the battery end is shot. Are those clamp-on ends a suitable replacement? I mean the kind where you strip off the insulation and bolt on the new one.
Henry M
04-28-2006 05:15:45
 Re: Another battery cable question in reply to Jim- DR, 04-27-2006 17:26:51
Go with Bob's way. It looks professional and makes the best connection which is what you need to take advantage of a good cable.
Of you are not into putting the ends on yourself, a local battery shop will put them on at an affordable price.
Jim- DR
04-28-2006 05:14:54
Would you use acid core or rosin core solder? Also is soldering paste the same as flux?
Bob
04-28-2006 06:55:48
 Re: Another battery cable question in reply to Jim- DR, 04-28-2006 05:14:54
I use rosin flux and either solid or rosin-core solder.
Bob
04-27-2006 20:06:08
A REAL auto supply store will have tinned brass cable ends.
Put a little soldering flux on the cable, insert it into the end, heat the cable end with a propane torch, and flow solder into it.
That makes a WAY BETTER connection than those shade-tree mechanic clamp on ends that invariably corrode and make poor contact after a year or two.
Let it cool, and tidy it up a bit with red or black heat-shrink tubing, available along with the cable ends.
David in Toronto
04-27-2006 17:48:06
I replaced all of these connectors with brass ones on my 2 battery John Deere 510 last year and they work much better.
BCnT
04-27-2006 17:43:06
yeah they work fine...IF you can find the brass replacement end theyre better but the lead type will work too.
