7040 hydraulic return
mo. tom
04-27-2006 16:51:41
WHERE is the return on the hydraulics on a 7040 Allis Chalmers tractor?
glr62
04-30-2006 18:31:45
 Re: 7040 hydraulic return in reply to mo. tom, 04-27-2006 16:51:41
Can't seem to scan a decent picture. Anyway, the two big lines from the piston pump are where you want to be. The real big line is the return, so tee into the line going to left side. This goes to a surge chamber, so piston pump will be delivering excess filtered oil to surge chamber. The other line is pressure and goes to remote valve stack.
Clear as mud?
glr62
04-29-2006 22:41:26
With three pumps there are several returns.
mo.tom
04-30-2006 03:22:53
 Re: 7040 hydraulic return in reply to glr62, 04-29-2006 22:41:26
I am trying to install hydraulic controls in the cab for my front end loader. I need to know where I can find a supply line, and a return line to hook into my new control. I've tried several lines, and it doesn't seem that it supplies enough fluid for the operation of the controls, but I have never found a return that seems to work. If you could please tell me or send me diagram , I would really appreciate it. Thanks,
tom
Joe(TX)
05-01-2006 09:56:18
 Re: 7040 hydraulic return in reply to mo.tom, 04-30-2006 03:22:53
I believe that the 7040 uses a load sensing pump. You need a special valve if it does. Closed center, load sensing.
Without the load sense signal, you will not get over 400 psi and very little flow from the main pump.
glr62
04-30-2006 18:45:07
Do you have a closed center valve? Does loader work at all? Hold a remote valve open and try your set-up.
glr62
04-30-2006 07:47:53
That helps!
Return to right hand filter. Nedd to tee into line coming from front.
Let me copy a diagram later today.
mo.tom
04-30-2006 11:51:55
 Re: 7040 hydraulic return in reply to glr62, 04-30-2006 07:47:53
Thank you so much!!! I'll sure be watching for it. I was using this tractor every day on the farm till I decided to start this project, and I really need it working again. tom
