B MAGNETO
RAY NORLIN
08-19-1999 17:56:36
I have a '47 AC B that has no spark in spark plug wires 2 and 3. Wires 1 and 4 produce spark. The plugs and wires are new. Problem occured before plugs and wires were changed. Points, rotor and condensor are also new and the engine is timed correctly. I would buy a new magneto cap but they are costly and it doesn't look worn or cracked. The engine will start but obviously doesn't run well. I need all the help I can get. Thanks ahead of time.
JC
08-23-1999 17:29:25
 Re: B MAGNETO in reply to RAY NORLIN, 08-19-1999 17:56:36
Ray, are the wires copper or graphite?, graphite Bad, copper GOOD, if your getting spark at two plugs, it's not your magnets or coil in your magneto.
John F.
08-20-1999 10:05:40
I assume you cleaned the contacts inside the cap.
Check the magneto bearings, if they're worn the
shaft may be wobbling.
