WD battery cables
Che
04-26-2006 12:43:36
I'm replacing the battery cables on my 1950 WD. It's 6 volt, positive ground, electric ignition. Should I use any particular cableor are they all the same?
Thanks!
Henry M
04-28-2006 05:17:37
 Re: WD battery cables in reply to Che, 04-26-2006 12:43:36
You might find 00 at a local battery shop. The local one here seems to always have access to the 00 welding stuff that gets salvaged from somewhere.
Kent of SW MO
04-27-2006 16:31:27
I would find the heavies welding lead cable you could find and build you own battery cables.
Kent
Kevin Bismark
04-26-2006 18:23:03
Yup, these guy's are on the money, the bigger the better within reason
old
04-26-2006 14:10:09
As Texas says the bigger the better. 6 volt system pull a lot of amps when turning the starter and big cables are need to do so. The auto type cable you buy at parts stores are #4 and will work but not for very long so you end up with trouble and wasted $$$. 0 or bigger
Texas Denny
04-26-2006 13:12:23
The brand is not a big issue. But the wire guage is. They should be 0 guage or bigger. You might be able to skate by with 1 guage if your engine is in exceptional condition. Smaller gauge than 1 that will not work.
