655 allis crawler laoder
Jeff Goettsch
04-25-2006 20:44:51
I'm looking for parts for a 655 allis crawler loader, any idea on where to get used or new parts for one. I need injector assemblys a flywheel and maybe undercarriage and a starter. thanks allot Jeff
jdemaris
04-27-2006 05:50:45
 Re: 655 allis crawler laoder in reply to Jeff Goettsch, 04-25-2006 20:44:51
Parts are availble from many sources, newly produced, new old stock, and used. I know where there's lot of used stuff, and the rest can be bought from any AGCO industrial dealer. The 655 is basically the same machine as the HD4. The 200 c.i. engine was updated a little, and the bottom rollers were changed a bit - but parts will interchange. Early engines were labeled as D2200, whereas the newer versions are called 433 engines. If you wanted to buy new OEM rollers for an HD3 or 4, AGCO will sell you the newer 650/653/655 series rollers to retrofit. Aftermarket rollers can still be bought from Berco. The updated 433 engine has stronger rod-bolts, valves with different angles, and that's about it - except for the 433I which is intercooled and turbocharged. The D2200 and 433 engine is used in HD4s, 650s, 1500s, 6060s, 6070s, 6080s, F2, F3, and K2 combines and 615 backhoe.
6080 Ag. tractor is also 200 cubic inches, but turbocharged and intercooled with 83
horsepower.
JohnHD4
04-26-2006 16:00:55
Try Minnpar. The last number I have is 612-379-0606. One of their dealers I've had good luck with is Struder Super Service in WI, 608-328-8331.
John
