D17 Split
J Henkle
04-25-2006 16:59:36
What is the best way to split this tractor in my garage with out an overhead hoist or training wheels for one half? I do have access to jack stands and floor jacks.
Need some creative ideas. I have basic tools and need to replace the clutch.
Also need recomendations on refurbed clutch kits or new. I only want to do this once.
Thanks, Jody
JMS/MN
04-25-2006 20:02:33
 Re: D17 Split in reply to J Henkle, 04-25-2006 16:59:36
The splitting ideas here are great, but you can replace the clutch by just pulling the engine. Is there another reason for splitting it?
Texas Denny
04-26-2006 07:14:43
 Re: D17 Split in reply to JMS/MN, 04-25-2006 20:02:33
Good observation. But is it easier to pull the engine than splitting the tractor? I would think they are about the same with the work being less in splitting. I've pulled engines on WD's and WD-45's and found that to be a lot of work. I split the D-17 with minimal effort - just requires planning. I guess I don't know the answer.
JMS/MN
04-26-2006 09:56:24
 Re: D17 Split in reply to Texas Denny, 04-26-2006 07:14:43
I would not say it is easier. More wrenching with radiator removal, etc. But if it's a one-time thing, choice is to cobble together a splitting stand or spend fair amount for good stuff. Safer to pull the engine- can do that with just a wire stretcher or come-along if need be. Don't need to worry about the tractor falling over.
Texas Denny
04-25-2006 18:46:39
If you have a narrow front, take each wheel off and reverse it. I like WDTom's idea for supporting the engine. I use a floor jack under the transmission and just roll the rear of the tractor back (after getting it apart with screw drivers and wonder bars and crow bars). I lay 12" planks under the tractor to act as a highway for the floor jack. Can't remember how many I had to use to get the right height. May have put the 2x12 over 4x4's to get it higher.
wdtom
04-25-2006 17:44:51
I am not to familair with the D 17, but know WDs and 45s. Should be about the samr as far as splitting. I would have two 2"x2"x1/4" angle irons extending down from the back of the engine area down to the floor with a base connecting them at the floor and long enough to extend 2 ft either side of the legs. Wedge/block thefront axle too so it won't want to allow the engine to piviot on the front axle. Borrow or make a dolly to hold up the front of the rear section where you split it. Use a stable pile of blocking here to build up to the tractor. Jack up the tractor 1/4" or so and put blocks in between the tractor and the dolly, this will preload it a bit and it won't be so likely to sag when you split it. Caredfully split, roll the back half back.
