D10 charging question
jerry l
04-24-2006 21:12:20
my d10 does not seem to be charging where should i start to look for the problems. its been sitting in the barn for many years runs fairly well for sitting so long thanks
steve(ill)
04-26-2006 19:33:59
 Re: D10 charging question in reply to jerry l, 04-24-2006 21:12:20
an alternator is more of a cube and made of aluminum. a generator is twice as long as it is in diameter and is mad of steel. a generator has two terminals on the top marked A and F. Most newer alternators do not have an external voltage regulator, the D10 did not have alternator. if you have an alternator and a voltage regulator, i would suggest removing and installing a newer auto alternator.---- if you ahve a generator, ground the F terminal and see if that starts charging. alos use a volt meter between the F and A terminals with F grounded and see if you get 13-14 volts output when running. if not, the generator is bad.
jerry l
04-25-2006 19:29:16
Denny- it has an alternator and voltage regulator
Texas Denny
04-25-2006 18:56:30
Does your D-10 have an alternator or a generator? A voltage regulator?
