hyd oil
Keith W from Pa
04-24-2006 16:54:41
what would happen if you would accidently add 80-90 gear oil to hydraulic system? Keith
jeffalex2
04-25-2006 05:51:07
 Re: hyd oil in reply to Keith W from Pa, 04-24-2006 16:54:41
I did the same thing...drained the system, filled it with kerosene...ran it for a couple minutes, then drained it, and put in the 20w that Allis called for...works fine
old
04-24-2006 16:56:54
Depends on the system. Some systems it would hurt a thing other system it could hurt things. Sort on need more info to be able to answer your ?
KeithW from Pa
04-25-2006 05:56:32
 Re: hyd oil in reply to old, 04-24-2006 16:56:54
Old,this on a MM jet star Keith
old
04-25-2006 08:01:27
 Re: hyd oil in reply to KeithW from Pa, 04-25-2006 05:56:32
But is the hyd system just for hyds or does it also have something to do with the tranny. If its just a hyd system your ok but if it also works things like the tranny you may or may not have problem.
Keith W from Pa
04-25-2006 08:28:13
 Re: hyd oil in reply to old, 04-25-2006 08:01:27
Old, thanks for the reply. the only other thing that uses this oil is the power steering. Keith
old
04-25-2006 10:53:40
 Re: hyd oil in reply to Keith W from Pa, 04-25-2006 08:28:13
You should be ok then.
