7060 dying
Dagwood
04-23-2006 21:26:16
My 7060 has died twice on two consecutive days while field cultivating. It appears that a breaker is blowing. The tractor suddenly loses power and dies. The idiot lights will be off and the electric fuel pump will not be running. If you try to start it you get nothing at all. After a couple of minutes the power is back and dash lights come back on and there will power to the starter and it will start right back up but run a little rough for a few seconds till the fuel system is fully charged.
Took a couple of minutes today and looked for loose connections and shorts but found nothing.
Any advice on what all to check for? Could breaker be getting weak? If the tractor dies again and I'm driving instead of the wife do you have any suggestions on what to check before the breaker resets itself if that is the problem?
BCnT
04-24-2006 07:04:06
 Re: 7060 dying in reply to Dagwood, 04-23-2006 21:26:16
i'd say breaker or dirty battery terminals...take clamps off battery posts and clean em up good...if breaker is within reach stick your finger on it next time it dies...you should be able to feel it reset if thats the problem...i've seen ignition switches do that too.
good luck
