crankcase breather....
compostibles
04-22-2006 22:55:37
On my Allis 620 (onan 20 hp engine), there is a crankcase breather which I guess is supposed to have a 90 degree angle breather tube-which is not there... per the owner"s manual, it says it is "equipped with an insulated ball check valve for maintaining crankcase vacuum." Is this something that is critical to have replaced? It sounds like a PCV tube on my car. Is it basically a one-way valve?
Thanks.
Jason
Richard (KS)
04-24-2006 08:24:11
 Re: crankcase breather.... in reply to compostibles, 04-22-2006 22:55:37
If I remember right on those small engines they use "crankcase pumping" to maintain a slight negative pressure in the crankcase, which helps to prevent oil leaks (in place of a PCV system). As this piston moves down it displaces air which is forced out past check-ball, then when it moves back up the cylinder the check-ball prevents air from entering c/case to fill the void. On average a slight negative pressure is maintained. HTH.
