allis chalmers manifold and generator HELP!!!!!
SAL BARTOLOTTI
04-22-2006 07:19:09
In reference to my intake/exhaust manifold should i be using any sealer around the manifold port holes??? Also have question about generator had one rebuilt and I installed do not think it is
charging any way to test it or any ideas on what i may do??? also installed the anti surge spring on the throttle shaft does not seem like it is in the correct spot can any body please help me
steve(ill)
04-22-2006 18:32:56
 Re: allis chalmers manifold and generator HELP!!! in reply to SAL BARTOLOTTI, 04-22-2006 07:19:09
should not need sealer on the gasket.----- to test generator, ground the "F" terminal to the frame of the tractor. see if it charges now. if not, jumper the A terminal around the cutout relay striaght to the amp meter. see if that works. - with t he F terminal grounded and tractor running, put a volt meter across the A and F terminals and you should measure 7 volts output (if the battery is connected. take off the A wire to ampmeter and you voltage will go up to 15 or so.
