Roll it or not?
Hoenes
04-21-2006 18:49:51
I found an old 45 for sale, that has been sitting for a while. The guy removed the gear shift assy. and forks etc. and had them rebuilt. He never got around to putting it back together. I would rather do this in the shop, instead of the woods. If I have the foot clutch locked down, and the hand clutch thrown forward, can I roll or winch the tractor onto a trailor without gears sliding out of position [no shifter forks are in position] and busting up the tranny?
acnky
04-22-2006 18:13:27
 Re: Roll it or not? in reply to Hoenes, 04-21-2006 18:49:51
yes, you can. hand clutch is link between trans and rear end,as foot cluth is for motor and trans.
Tramway Guy
04-24-2006 07:00:43
 Re: Roll it or not? in reply to acnky, 04-22-2006 18:13:27
Incorrect!!! The hand clutch is between the hydraulic pump/PTO and transmission. Not between the transmission and rear end!
Some of the 'WC' tractors had the disconnect like you say, but not the 'WD' or 'WD-45'.
Tramway Guy
04-21-2006 19:03:53
The transmission is always connected to the rear wheels, no matter what position the clutches are in. If you are in Neutral, you shouldn't have any problem rolling it. Go slow in case the shift collars start to catch.
