WD front end question
JackT
04-21-2006 09:12:10
On my WD45"s steering box (wide front) there is what appears to be a 1" plug on the top-left side. Is that to lube the worm gear? What lube should I use, 90 Wt?
Thanks
Guyzoo
04-21-2006 17:26:24
 Re: WD front end question in reply to JackT, 04-21-2006 09:12:10
yep,The top plate is for ajustment. Check in the upper front of the steering box in the middle should be a grease zerk. That lubricate the upper bearing under the cover. The plug you mentionned use 80W-90 and I recommend draining it first.(not sure of the location of the drain plug). it is easily removeable using a 1/2 drive ratchet.
the quantity of lube is 1 quart U.S.
HTH Guyzoo
Aaron SEIA
04-21-2006 16:06:28
Should be a square plate with 4 bolts on top of the casting, thats the assess for lube. Think the reccommended oil was 90 or so, but some gun grease or corn head grease would work best, the seals probably won't hold oil in any more. The soft plug is there to fill the hole that was made milling the steering shaft end bearing hole. Take the top plate off and you'll see.
Aaron SEIA
