WC carb kit
Michael D.
04-16-2006 08:08:24
I have been looking around for a carb kit for a zenith. The numbers on the carb are, U3195 and 7078C. I have checked all my sources but none of them have a kit just a gasket. Are these carbs rebuildable? It looks pretty clean in side but I havent took it apart to check out the float and jets. Worried I cant get parts for it. Thanks for you help in advance.
Jerry Coulter
04-16-2006 11:21:20
 Re: WC carb kit in reply to Michael D., 04-16-2006 08:08:24
According to the WC parts book, your carburetor fits units prior to serial #74330. The only kit listed is gaskets. Other parts have to be purchased separately.
old
04-16-2006 08:41:01
I would recheck those numbers. None of them cross over to what my catalog says. What I have for numbers for a WC are. 10698A, or 8979. And if its an early 1934-1937 the numbers are 7178
Michael D.
04-16-2006 09:04:03
 Re: WC carb kit in reply to old, 04-16-2006 08:41:01
third party image
Here is a pic of the tag on the carb. We have two of these with the same numbers.
old
04-16-2006 09:15:26
 Re: WC carb kit in reply to Michael D., 04-16-2006 09:04:03
I almost bet if you would compare that with the carb numbers I gave you one of the kits would work for your carb. I've found a kit will sometimes cover 10-20 differant carbs.
