Mastevt
04-14-2006 15:24:41
I have a 49 WD, that has been upgraded with the WD45 engine, it has the aftermarket 3 point. I have 2 bottom plow, I'm only plowing about 7 inches deep. It does ok, but I have to have a hand on the control at all times and adjust constantly. It pulls it just fine, but when the plow wants to go a little deeper than normal, the tractor stops moving and spins it's tires. I don't have fluid in them, and am not wanting to do that if possible, and no weight up front. It's in great condition, new tires and all. I can't get the draft control, or whats called traction control to work. I have the lower adjustment screw(A) turned out of the body, B turned into the body seperating the plates, and srew D out as far as it will go, all just like the picture shows, I have taken all the linkages into work and repaird them, so very little slop is left. I have adjusted the linkage acording to a post by David_T, where you start the tractor and raise the arms to max height, and shut the tractor off, then stood on the arms and slowly lowered the control to about 1/2 way in the quadrant, so as to lower the arms completly, then adjusted the the outer plate/linkage so they are in the detent when plates are locked together. So far I'v done everything I can that I have read on posts here, but to no avail, I've tried playing with the link rod adjustment on the drawbar, but that only seems to change the position of my control lever on the quadrant. Does anyone have any suggestion as what to do next? Do you think that the large spring down on the drawbar is weak, and is collapsted all the way, so in effect cant move the link rod, and control lever? any help would greatly be apprecitated, thanks.
