Gleaner-WD engine swap
jAcK
08-17-1999 15:13:24
I have found an old gleaner combine,and it is complete.What was the model number on the combine in which the engine will bolt up to on the WD.I was told that the combine four cylinder was over 50 horse stock,and I want one for pulling purposes if this is true.Thanks.
Frank Mann
08-19-1999 18:22:23
 Re: Gleaner-WD engine swap in reply to jAcK, 08-17-1999 15:13:24
Jack, I own a 1967 E model combine that has a D 17 engine. Frank NEO
AL
08-18-1999 07:13:35
GOT ONE DONE THAT PAY ATTENTION TO USING A WD GOVERNOR GENERATOR BRACKETS ETC. YOU MAY HAVE TO TWEAK HERE AND THERE USE THE BEST PARTS YOU HAVE USE THE FULL FLOW D-17 OIL FILTER SYSTEM GOOD LUCK AL
WALT
08-17-1999 16:50:09
The Gleaner combine you are probably refering to is an "E" series.
The engine is more closely related to the D-17 than the WD.
