B Pinion Shaft Oil Seal Problem------
Pappy
04-12-2006 20:15:41
Trying to find proper fit of oil seal on the pinion shaft of a "39 "B" Allis Chalmers.
The old seal has only a number 8 on it.
The parts book shows the number 800351.
The C-R Seal is 11800 which can be found at auto parts stores.
Problem: The new C-R Seal, 11800, is correct for the OD, (2.00") but the ID is tight on the shaft, making it difficult to install the shaft without damaging the seal. By "tight on the shaft", I mean that the metal part of the seal is just about the same diameter as the shaft, causing the rubber to be pushed out of the seal when you install the pinion shaft.
Any good ideas on an alternate seal that would fit and give some clearance?? Thanks!1
Bob
04-12-2006 21:08:52
 Re: B Pinion Shaft Oil Seal Problem------ in reply to Pappy, 04-12-2006 20:15:41
Here's the data sheet for a 11800:
Link
Here's the data sheet for a 12456:
Link
The also make a seal in another series that's only .031" larger, the 12131, which is also WIDER:
http://www.chicago-rawhide.com/catalogs/457010/sealdetail.asp?s=12131
Pappy
04-13-2006 16:46:45
 Re: B Pinion Shaft Oil Seal Problem------ in reply to Bob, 04-12-2006 21:08:52
Bob----Thank you for the information. The 12456 Seal is exactly what we needed. Evidently, our parts man was confusing 1.250 with 1 1/8 inches.
Have a wonderful day!!! Pappy
Bob
04-13-2006 20:51:30
 Re: B Pinion Shaft Oil Seal Problem------ in reply to Pappy, 04-13-2006 16:46:45
I'm glad to hear that worked for you, and thanks for letting me know!
