D-17 fuel pump
John in TN
04-10-2006 19:14:27
Does the series I D-17 have an engine fuel pump?
The one I looked at today has one and the owner says the engine driven fuel pump is bad.???
thanks john
John in TN
04-11-2006 07:56:59
 Re: D-17 fuel pump in reply to John in TN, 04-10-2006 19:14:27
thanks I didn't think about the E combine. I'll ask him. He did put an electric pump on it. He said some times it runs for along time and some times it onl runs a short time. I think that maybe the rubber hose from the tank to the carb. Do you think that is the running problem?
thanks
John
JMS/MN
04-11-2006 07:08:32
Original should be gravity flow from the tank down to the carburetor, with a sediment bulb. Was the original engine replace with one from an E combine? That would have a fuel pump, but doesn't need it in the tractor application.
