Allis-Chalmers B
dalton
04-10-2006 19:02:55
I should of said that the battery is new and fully charged as well...thanks
jeffalex2
04-11-2006 18:42:18
 Re: Allis-Chalmers B in reply to dalton, 04-10-2006 19:02:55
Also depends on how long the previous owner used a 12volt batt on a 6volt starter...may be burned up windings. Is the generator 12 volt? Is there a regulator or cut out relay? Might be pitted contacts on the starter switch...you can loose alot of current flow there.
Warren Jerome
04-10-2006 19:37:26
See if either the cables or the starter itself are getting hot when you try to start it. If all the connections are good, (looks are deceiving) and the battery checks OK, you"re down to the starter assembly. That would include any solenoid.
old
04-10-2006 19:09:05
New batterys aren't alway good batterys. Check your other post for more info
