Allis Chalmers B
dalton
04-10-2006 18:35:55
I recently purchased an 1941 Allis-Chalmers B. My question is it has a 12 volt battery and turns over slow. It just clicks for a second and the engine trys to turn over. It will start and run after a few clicks. this has a magneto a generator, starter, no lights and a 12 volt battery...does this sound right or should I get a 6 volt battery..
Ted in NE ohio
04-14-2006 11:54:55
 Re: Allis Chalmers B in reply to dalton, 04-10-2006 18:35:55
When 6 V starters are run on 12V the brushes wear down faster. Check them out.
dalton
04-14-2006 13:34:32
 Re: Allis Chalmers B in reply to Ted in NE ohio, 04-14-2006 11:54:55
Thanks everyone
old
04-10-2006 19:07:32
Could be a few things. Weak battery as Bob says and needs charged. Bad battery cables/conections. Solinoid going bad. Also sounds like the chargeing system doesn't work and that also causes problems
chalmersbob
04-10-2006 18:52:49
sounds like the battery needs to be charged. BOB
