B Pick-Up Plows
Rod (NH)
04-10-2006 11:15:25
Has anyone ever seen any 2-way pick-up plows for an AC-B like mine?
I have never seen any like them so I am curious if there are others out there somewhere. There must be some but they may be buried in the dustbin of history, so to speak. They apparently are not as common as the standard AC pick-up plows. I am told that there were "several" aftermarket manufacturers for B plows, particularly during the war years, but I don't know how true that is.
third party image Rod
Te in NE OH
04-14-2006 12:01:37
 Re: B Pick-Up Plows in reply to Rod (NH), 04-10-2006 11:15:25
I Have a set for a B or C. I plan on putting them on a C. When you go to a big Allis show you will find 2 or 3 restores tractors with two way plows. Unusual but not rare,
Chris (OR)
04-11-2006 10:56:27
Does anyone make plows for these tractors this day in age? I have about 50% of a hand lift one for my B but I can't find the rest of the linkage to make it work.
I know that Woods still makes mowers for this vintage tractor (I have one and it works great). Is someone making plows for them? I have a '39B with out hydraulics...
Thanks
Chris
ed in cny
04-12-2006 09:58:56
 Re: B Pick-Up Plows in reply to Chris (OR), 04-11-2006 10:56:27
I may have some parts you need. I would have to see if I can get an inventory of what I have. I have the two way plow set but the last owner made them into hydrolic pickup. Let me know what you may need.
Rod (NH)
04-11-2006 17:25:36
Chris,
You're not going to find anyone who makes that stuff nowadays. The closest you will come new is a complete one or two bottom 3 pt type plow that needs a 3 pt hitch and hydraulics. The specialized hand lift equipment was unique to the B and went out of favor as soon as B hydraulics became common. Depending on which 50% of the hand lift mechanism parts you now have, it may be possible to make the remaining parts yourself - or have someone make them for you. The hand and hydraulic lift versions of the standard AC-B pick-up plows shared some common parts. The rockshaft is one such part. I have seen those on ebay every once and a while. You have to be careful though. While many B&C parts interchange, that rockshaft assembly is not one of them. The B hand lift lever assemblies (and assist springs) are the parts that are unique to the hand lift arrangement. I've never noticed those anywhere. However, if they (right and left assemblies) are the parts you already have, you're lucky and making the others is a possibility. It's a shame that unique implement mounting parts get separated from the equipment itself over the years. I guess that's a sad fact with the old proprietary mounted implements that were used on the B. Parts get sold separately or end up at a scrap metal dealer or in a landfill.
Rod
David Clem
04-17-2006 10:43:37
 Re: B Pick-Up Plows in reply to Rod (NH), 04-11-2006 17:25:36
I need photos of the hyd. lift parts. I have most of the linkage on my 56 B. I also have the hyd. pump to put on now and need help with this. It was my late fathers tractor now mine and want to bring it back to life. Any help would be appriciated.
Butch(OH)
04-10-2006 13:34:03
Rod, I have a 2-12 plow for a B or C that was made by them. Came from the Finger Lakes region of NY.
Rod (NH)
04-11-2006 17:16:04
 Re: B Pick-Up Plows in reply to Butch(OH), 04-10-2006 13:34:03
Butch,
Are they trailing or mounted? Do you have any pictures?
Rod
BCnT
04-10-2006 12:42:43
we had something similar when i was a kid...pretty sure my grandfather built ours tho...used it to hill up sides of watermelon beds...galveston island cancer got it tho...only thing left is a stain behind barn.
Duncan
04-10-2006 12:05:24
Yes I have,used one on a C,nice little plows,go back and forth in the same furough,no dead furough in the middle of a garden or feild.Love to have a 2-14 2way for my WD.
Rod (NH)
04-11-2006 17:13:53
 Re: B Pick-Up Plows in reply to Duncan, 04-10-2006 12:05:24
Duncan,
WIARDs or AC? The WIARDs I have wouldn't fit a C without some modification because of the wider track on the C.
Rod
