Need advice about Allis 160
Jrry
04-10-2006 10:29:45
I purchased an Allis 160 this weekend but the seller said he parked it two years ago when the transmission and the pto went out. I've got a service manual ordered and will pick up the tractor this weekend. Just wandering if you guys have any ideas as to the problem. I'm guessing clutch problems. Will it require splitting to repair if it is. I'm not famalier with these tractors.
thanks, Jerry
PAUL BAXTER
04-10-2006 11:06:56
 Re: Need advice about Allis 160 in reply to Jrry, 04-10-2006 10:29:45
It is probably the clutch and yes, you will need to split the tractor. There is a set of shims that can be accessed by an inspection cover on the bottom of the bellhousing. You can remove a shim from each bolt to make up for clutch wear and prevent grinding of the pto when you try to put it in gear. If someone has already done this then you are out of luck. You also need to place the correct number of shims in place when replacing the clutch so that the proper number of them can be removed later as required when the new clutch wears. Spltting the tractor is quite a chore.
Jrry
04-10-2006 11:17:45
 Re: Need advice about Allis 160 in reply to PAUL BAXTER, 04-10-2006 11:06:56
Thanks Paul. I'll check the inspection plate first. It may be awhile before I will have the time to split the tractor though.
