WD Crankshaft Seal!!!
Bill {Antique A
08-16-1999 19:55:31
My WD started pouring oil out from under the crankshaft pulley. I assume I need to replace the crankshaft seal. What goes into replacing this. Do you have to take the head off and the pistons out?? All help would be appreciated. Thanks Bill {Antique Acres}
D. DIXON
08-18-1999 18:27:27
 Re: WD Crankshaft Seal!!! in reply to Bill {Antique Acres}, 08-16-1999 19:55:31
My tractor manual says that it is possible to replace the front seal without removing the timing gear cover, but that you should loosen all the cover bolts and then run the engine with them loose after instaling the new seal to facilitate centering up the new seal. After having just rebuilt my WC I can tell you its a pain to install that seal even with the cover off because there is a circular coil spring inside the seal and the darn thing wants to become dislodged. and the first seal I got from the dealer was a lot flimsier than the original, and I bent it just trying to press it in. The second was heavier and went right in. Well the book says it can be done so good luck
Cory
08-22-1999 17:00:42
 Re: Re: WD Crankshaft Seal!!! in reply to D. DIXON, 08-18-1999 18:27:27
Bill i just put new seals and a clutch in my 49 WD. It took me aprox. 1 hour to pull the engine out of the frame. You will need to pull the front pulley and remove the oil pan and timing gear cover to do a through job. I then removed the main bearing caps and using two pinch bars pryed the crankshaft down about 1/2 inche. Since i needed to replace my clutch anyway the flywheel was also taken off. This allowed good installation
of the seals. If they aren't, it requires alot of REWORK. My WD has 63 hours on it and so far so good. Good luck!
