B/C Mower
Rod (NH)
04-08-2006 09:36:15
third party image
Anyone know what this hooked rod is used for on the B/C mower assembly? The instruction manual calls it a "lift shaft lock". It appears to have something to do with attaching and detaching the mower assembly from the tractor but it's not clear at all - at least to me. On detaching the mower assembly, it is stated to "Hook Lift Shaft Lock in place as shown at "C" Plate 1. Move lever forward and lock in the first notch in ratchet, relieving the spring tension". This statement doesn't make sense to me as moving the the lift lever forward with that lock engaged would increase spring tension not decrease it. I have never used this part for anything in over 40 years of using this mower. I doubt that Dad ever used it either before that. If anyone has ever used this piece for anything, I'd appreciate knowing about it. Especially if it somehow makes installing and removing the mower an easier task.
Thanks,
third party image Rod
ed in cny
04-12-2006 10:15:18
 Re: B/C Mower in reply to Rod (NH), 04-08-2006 09:36:15
Theis hook is when you arn't using ther hydrolic pump to hold it up. It flips over and hooks to the bolt in front and it's locked in. That hook will hold up the mower. I hope this helps.
old
04-08-2006 10:30:21
Doesn't look anything like what I have on my C but then on the other hand who knows what all I'm missing on this one
