Allis C runs now. And has the sickle mower mounted
old
04-07-2006 19:35:57
Now all I have to do is figure out where to find a pulley for the PTO shaft or make one. Also have to figure out how to hook up the hyd cylinder so it works like it should or at least works. Sort of a messed up set up on it right now. The guy took a piece of pipe and hooked to the the cylinder and also did some funny things with the spring that helps do the lifting on it. I found out most of the parts can not be had new any more. Oh well guess I'll be makeing a few parts.
Rod (NH)
04-07-2006 20:52:25
 Re: Allis C runs now. And has the sickle mower mou in reply to old, 04-07-2006 19:35:57
Hi Old,
I've seen those pulleys on ebay every once and a while. It's a shame that they ever get separated from the mowers they go with, along with some other separate, but unique, mower parts. You also can get a workable pulley from a power transmission supplier such as Browning. I can get you the particulars on the AC pulley if you wish to proceed that way. I am assuming you have the B/C belly mower that uses a single v-belt. I don't know what pieces you may already have that are part of the separate hydraulic lifting mechanism for a C. I know they are different than those used on a B, particularly the early B mowers. However, you might get some ideas for a custom arrangement by looking at what I recently did to add hydraulic lift capability to my B mower. You shouldn't need that spring at all if you are going with hydraulics - unless you want to retain a hand lift capability. I found I had to loosen the spring up a lot when I started to use the hydraulics because (in combination with the hydraulics) it retarded the speed at which the cutter bar would lower. I like the cutter bar to drop fairly quickly when I want it to - not 10 seconds later.
third party image Rod
old
04-07-2006 21:18:21
 Re: Allis C runs now. And has the sickle mower mou in reply to Rod (NH), 04-07-2006 20:52:25
Well when I started to play with this thing it had the little cylinder on it and it would lift it very high. I have since took a cylinder from a WD lift and put on it and that seens to work better/faster. As far as the pulley problem I'm thinking about adding an idler type pulley to tighten up the belt. That way I could set it up so I could sort of kick it out of gear but still use the lift. I want to be able to mow hay and rake hay with this tractor with out removeing the mower.
