1948 allis chalmers b oil pump question
cjim
04-06-2006 16:29:31
must have a problem with my oil pump in my 1948 allis chalmers b if i don't prime pump with oil can before cranking over won't have oil pressure...any idea why? i assume have a broken or sticking spring that holds pump blades out..and after priming they stay out when running?....anybody know a soarse on line for a oil pump rebuild kit?....thanks jim
Dale(MS)
04-08-2006 07:50:45
 Re: 1948 allis chalmers b oil pump question in reply to cjim, 04-06-2006 16:29:31
CJIM, if you have good oil pressure after priming and stays good while running I would think that you have a pressure relief ball or pressure relief spring problem. When the engine is not running the the pressure relief ball and spring act as a check valve and hold oil in the oil pump body. Ball could be rusted or pitted and/or the spring could be broken or tired. Also could be the ball seat might be pitted. There is a little pin that holds the spring and ball in place and it could have come loose or something. Dale
chalmersbob
04-06-2006 17:27:41
i have a 49 c with the same problem. i was told to check the pickup tube for crack. or to pull the pump and check the pressure relief valve. tractor engine had been rebuilt before i bought the c. i had to put it together, oil pump, flywheel, clutch. etc. i checked the pump before mounting. took it apart, cleaned, checked everything, setup clearance on rotor with new gaskets, and still i have the problem. now i must drop pan to check tube and possibly split tractor again. BOB
