48 wc won't start
Michigan dave
04-06-2006 11:27:41
This tractor ran for about two hours after a long Michigan winter. It was shut off, then would not re-start. It appears that there is no spark. What is the best way to determine if I do have spark? I attempted to ground a plug while cranking. Will this method help me identify an ignition problem? Thanks much.
Dave B
Dave NE IA
04-06-2006 17:51:41
 Re: 48 wc won't start in reply to Michigan dave , 04-06-2006 11:27:41
Do you here the mag click as you turn it over? If you do not hear it just hit the mag with the crank or a hammer. Common sence is a factor, but you can smack it pretty good to get the impulse to catch. Simple terms is a big spring turns the inside of your mag to make a spark at full RPM's. When cranking at slow speed a trip holds the spring drive and lets the spring snap it (like fast RPM) to create enough spark. With a mag you should easy hear a snap when starting. Dave NE IA
Michigan dave
04-07-2006 05:42:56
 Re: 48 wc won't start in reply to Dave NE IA, 04-06-2006 17:51:41
Thanks for all the input, I will pay special attention to the mag. This tractor is at my in-laws place and I will give it a go this weekend. Many thanks!
Michigan dave
old
04-06-2006 12:06:16
Take a good spark plug and hook it up to one of the plug wires and ground it on the engine. Then turn the engine over and watch for a spark at that plug. May take a few turns of the crank to see a spark. If no spark I'd check the point, condenser and cap and rotor. Is it a mag system or a battery type ignition. Both can have differant types of problems so it would be nice to have a little more info
Michigan dave
04-06-2006 12:54:06
 Re: 48 wc won't start in reply to old, 04-06-2006 12:06:16
Thanks for your help HF. Please be patient with me. I"m not afraid to get my hands dirty but I"m not very familiar with this tractor. I beleive it"s a magneto type ignition, how can I tell for sure?
old
04-06-2006 13:19:52
 Re: 48 wc won't start in reply to Michigan dave, 04-06-2006 12:54:06
Does it have a 4 plug wire type of cap or is it a 5 wire type cap. If the cap has 5 wires one of them will go to the coil and that would be a battery ignition system. If the cap only has 4 wires comeing off it then you have a mag system. Either way you probably need to replace the points and condenser
Michigan dave
04-06-2006 13:29:37
 Re: 48 wc won't start in reply to old, 04-06-2006 13:19:52
definitely a 4 wire cap. I will replace the points and condenser. Thank you again.
old
04-06-2006 13:35:42
 Re: 48 wc won't start in reply to Michigan dave, 04-06-2006 13:29:37
Point gap is .020 on that system
