B electrical system
CHEVY 66
04-05-2006 09:42:41
Friends, Been having trouble with my B electrical system. Replaced the wireing harness now the ammeter shows discharge in both switch positions, about 2 amps, put the lights it goes to 10 amps. Thanks in advance for any help.
souNdguy
04-05-2006 13:41:20
 Re: B electrical system in reply to CHEVY 66, 04-05-2006 09:42:41
Any chance you reversed the wires ont he ammeter. on my G.. I show a slight charge, and with switch out a heavier charge... sound similar?
If you have a vom.. check voltage if you have 7v at the battery.. you are not discharging...
soundguy
chevy 66
04-08-2006 16:03:55
 Re: B electrical system in reply to souNdguy, 04-05-2006 13:41:20
Thanks soundguy, but according to the wiring diagram all the wires in the right place. I know the generator is charging, if you disconnect a battery post the tractor will keep running.
souNdguy
04-08-2006 21:16:06
 Re: B electrical system in reply to chevy 66, 04-08-2006 16:03:55
Well.. if it is charging, and the meter reads backwards.. guess what.. meter is either wired backwards.. or you have reversed polarity.. ie hooke dthe battery up backwards... That amp meter is just a shunt voltage meter.. and it is polarity sensitive.. and DC electrons go '1' way.. so not too hard to trouble shoot this one...
Soundguy
