Allis C carb problems
old
04-04-2006 08:37:20
Well I have had the carb apart 4 or 5 times now and it will not run with out being choked. Its the carb with the nonadjustable main jet. I'm thinking about drill the jet out just a little bit, what do you guys think?? Ya I checked to see if it was a manifold problem by spraying carb cleaner in the manifold when it was running and there was no change in the engine. I have also ran a tip cleaner through all the passages in the carb. Any body got any ideas on this one??
Thanks
russ1
04-04-2006 12:58:51
 Re: Allis C carb problems in reply to old, 04-04-2006 08:37:20
Hi Old. It sounds like it is getting air somewhere after the carburetor. Drilling your jet to a larger size will more than likely just mask the cause. I would check everything again before i altered the jet.
hang in there. I have occasionally had to recheck several times before I found the leak.
Russ
old
04-04-2006 13:25:53
 Re: Allis C carb problems in reply to russ1, 04-04-2006 12:58:51
Well I opened it up one more time. I checked and rechecked every thing. I also changed which gasket I used. Well its working the way it should be now so I'm not sure what I did but what ever it was I did it right LOL.
russ1
04-04-2006 15:29:18
 Re: Allis C carb problems in reply to old, 04-04-2006 13:25:53
Good
