D-15 oil transfer
Dale Steinback
04-02-2006 13:07:49
On my D-15 the oil transfers from the hyd. pump section to the differential section even when the pto and 3 point are not in use. Have to keep adding oil to the hyd. pump section and rear end always overfull and leaking.
Thanks.
Dale Steinback
04-03-2006 12:18:49
 Re: D-15 oil transfer in reply to Dale Steinback, 04-02-2006 13:07:49
Try again. I have a lot of trouble with my email.
Dale
Texas Denny
04-03-2006 07:22:21
Dale, I tried to send you an email but it came back to me indicating an address failure. I sent another with the same result. Send me an email again.
Denny
Texas Denny
04-02-2006 15:22:20
Two possible problems. One is the hydraulic cylinder inside the differential case. It has seals around the cylinder piston that may have failed. The other is a hydraulic hose that connects to this cylinder. It may have sprung a leak.
Last year, I had the same problem on my D-17. It turned out to be the o-ring and sealing rings on the piston. You will have to pull that big casting off the rear of the differential that contains the lift arms. It's pretty heavy. I had a shop crane to do the lifting. I think the parts to fix it came to about $25 from Agco Allis (o-ring, two seal rings, and the large casting gasket). Don't have a clue as to the cost of the hose.
