D-14 SPECS.
DitchWI
03-31-2006 11:44:33
Can anyone tell me what the horse power of a D-14 is ? Has anyone used one with a loader on it and if so how did it work out ?
John (MO)
04-02-2006 08:12:23
 Re: D-14 SPECS. in reply to DitchWI, 03-31-2006 11:44:33
No problems with a loader as long as the cylinders are correct for the AC system. Even without power steering, mine worked fine.
Greg Rosier
04-02-2006 06:54:46
Have a Paulson trip bucket loader on a D14. Loader is slow to lift (D14 hydraulic pump is Hi Pressure; Low Volume); however does lift a loaded 7' snowbucket with no problem. Live power is an asset when loading as one can ease into the snow pile and lift bucket at same time. Power Steering is also a real plus with the loader.
Brad Wright of MO
03-31-2006 15:27:59
Heres what I found!!
Allis Chalmers
D14
Manufactured: 1957 - 1960 Total built: 23,050 Factory: West Allis, WI Cost: (US Dollars) $2,900 (1960) Power: Drawbar (HP): 31 Belt (HP): 34 Plows: 3 Engine: Manufacturer: Allis-Chalmers Fuel: gasoline Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 3.50x3.875 Displacement (ci): 149 Compression: 7.5:1 Rated RPMs: 1650 Torque (ft-lbs): Firing order: 1-2-4-3 Oil capacity (qts): Spark plug gap: 0.025 Point gap: 0.022 Engine: Manufacturer: Allis-Chalmers Fuel: LP gas Type: vertical I-head Cylinders: 4 Bore/Stroke (inches): 3.50x3.875 Displacement (ci): 149 Compression: 8.5:1 Rated RPMs: 1650 Torque (ft-lbs): Firing order: Oil capacity (qts): Transmission: Type: sliding gear Forward: 4 Reverse: 1 Transmission: Type: Power-Director Forward: 8 Reverse: 2 Capacity: Fuel (Gal): 14 (22.3 LP gas) Cooling (Qt): 9 3-Point: Category: snap couple Lift (lbs): Power Take-off (PTO): Type: independent Rear speed (RPM): 540 Tires: Ag front: 5.50-16 Ag rear: 12.00-26 Dimensions: Weight (pounds): 3880 Wheelbase (inches): 85.75 Length (inches): Width (inches): Height (inches): 141 Ground clearance (inches): 25 Electrical: Battery volts: Ground: Battery cold-cranking amps: Alternator amps: Nebraska Test: Test Number: 623 Test Date: June 1957 Engine: gasoline Belt HP: 34.1 Drawbar HP: 31 Max pull (pounds): 2,396 Nebraska Test: Test Number: 645 Test Date: April 1958 Engine: LP gas Belt HP: 31.9 Drawbar HP: 28.7 Max pull (pounds): 2,204 Serial Numbers: Location: Torque housing 1957 1001 1958 9400 1959 14900 1960 21800
