Allis C runs now.
old
03-29-2006 13:31:09
I had it running just a little bit ago about 3:15 CST. No radaitor on it yet or valve cover but it does run. After I got the fireing order right that is. LOL. Will not run when choked all the way or with it open all the way so I guess I need to rebuild the carb, but that doesn't surprice me any. Oil preassure gauges moves up about to center of the gauge but since theres no numbers on it I don't know how good or bad that is but at least it has some oil preassure. Now I get to do all the fun stuff like wire it and put all the sheet metal back on etc.
Thanks guys for the help.
Keith-OR
03-29-2006 13:43:54
 Re: Allis C runs now. in reply to old, 03-29-2006 13:31:09
So Rich, when you going to go in the house and bring the "Better Half" out and show her, her new tractor????? LOL...:>)
Need it all painted up nice a pertty all the original decals, new tires, nice fancy, soft seat. And don't forget nice after market 3pt system...Oh and AM/FM radio with headset....:>)
Keith & Shawn
old
03-29-2006 14:40:01
 Re: Allis C runs now. in reply to Keith-OR, 03-29-2006 13:43:54
Shoot I have to be able to drive it around and work out all the bugs before she will ever get close to sitting on it. And then I have to figure out how the belly type sickle mower goes on. I will have to cut a piece of plywood for the seat and have her cover it but other then that she will not be around it till its ready to drive. You wouldn't believe how bad the carb was. Main jet was so clogged up that I had to use the tip cleaner for my torch to open it up. LOL
run2pol
03-29-2006 18:16:56
 Re: Allis C runs now. in reply to old, 03-29-2006 14:40:01
I was just reading through the topics an i seen your Allis C talks, well we have opposite problems i have a belly mounted 5' sickle bar on it my Allis C but i am having trouble getting it to run. I beleave its a timing issue.
old
03-29-2006 18:44:40
 Re: Allis C runs now. in reply to run2pol, 03-29-2006 18:16:56
Well I did have a timing problem this morning, sort of. I have the plug wires on all wrong so it was way off on timing. I will be mounting a 5 foot sickle mower in it once I have it running good but since I just got it running it will be a week maybe 2 before I start working on that part of it.
