WD or WD45?
JBF203
03-28-2006 13:26:25
Need help in identifing a tractor that I'm possibly going to buy. Heres what I know:
Serial # 165522 (wd45/1954?)
Curved shifter handle.
Motor has inspection plate on side opposite carb
"Power crater sticker" on inspection plate
45 with an update wd motor?
All help is appreciated!
Bob N.Y.
03-28-2006 17:25:19
 Re: WD or WD45? in reply to JBF203, 03-28-2006 13:26:25
That might be the one my brother had.
Texas Denny
03-28-2006 13:49:13
I think Old has nailed it. The rear axel and transmission are definitely WD-45. But the engine is not. The WD engine is not an update - it is an older engine. If stock, the WD engine has less horsepower.
old
03-28-2006 13:30:52
Well with the cover on the side of the engine that would make it a WD engine not a WD-45 engine. What it probably is, is a tractor made from 2 or 3 tractors.
JBF203
03-28-2006 13:59:03
 Re: WD or WD45? in reply to old, 03-28-2006 13:30:52
Now my question is? and I agree with you both that its a 45 with the wd motor. Can the transmission top covers be swaped out to put the straight shifter in the 45 trans. I think its easier to shift with the straight shifter.
JMS/MN
03-29-2006 09:29:15
 Re: WD or WD45? in reply to JBF203, 03-28-2006 13:59:03
No. You can switch towers- they are the same. I used a WD tower on my WD45, drilled through the one hole to make another for the second shifter pin. But the straight WD shifter is not the same length as the WD45 shifter from the pivot ball down to the bottom. So either the gears in the box are in a different location or forks are different.
old
03-28-2006 16:27:51
That I can't answer for you. I have never tried to do it. I do know some of the last WDs came out with the bent shifter so maybe it would work
