Can 3pt be added and work well?
freddie
03-28-2006 08:27:44
Looking at a WD with pto but no 2 or 3pt, how would an after market work on this tractor, was quoted about $500 for part? Its from the 40's & is a wide front. Are the pto's live on these? Thanks
Dave L
03-28-2006 18:47:08
 Re: Can 3pt be added and work well? in reply to freddie, 03-28-2006 08:27:44
Old is absolutely right,It is a sort of live setup when using the hand clutch.Can be handy as heck.
Dave
BobHnwOh
03-28-2006 15:56:17
Freddie,I made my own,works with drawbar,Bob. third party image
JMS/MN
03-28-2006 14:39:56
The pto and hydraulic systems are live- not independent. No such thing as a semi-live, or sorta-live pto.
old
03-28-2006 11:55:34
3 Points can be hard pretty easy to them but you also need the lift system/hyds to do so. I have a parts tractor with the lift system but I don't have the 3 point arms for makeing a 3 point. My e-mail is open. Also the PTO is a sort of live set up useing the hand clutch.
Dave Grubb
03-28-2006 10:15:04
Forgot to answer your PTO question. The PTO is what I would call a semi live system; it does not have its own independent clutch. To engage the PTO you push in on the foot clutch, pull out on the PTO gearbox lever, ease the foot clutch back out. The foot clutch disengages the transmission, PTO, and hydraulic pump. The hand clutch disengages the transmission only.
Dave Grubb
03-28-2006 10:02:16
If you click on the 'Tractor Parts' on the left side bar of this page you will see offerings for the 3 point systems. You could also put the AC Snap Coupler system on you tractor.
