WD-45 oil change
rjl2
03-27-2006 17:48:51
I just got an Allis Chalmers WD-45 and it needs an oil change. I did a search and it looks like I can use a Fram C-159 oil filter, is this right? Also, what kind of oil and how much should I use?
steve(ill)
03-28-2006 19:29:47
 Re: WD-45 oil change in reply to rjl2, 03-27-2006 17:48:51
C159 is correct. either oil will work, but im with Farmer. the multi viscosity is better oil for all around use. starts better in winter and maintains pressure in the summer. i use 10w30 in all gas tractors.
Dairy Farmer
03-27-2006 18:09:34
Yeah, thats the right filter and you need 10W-30 and put 5-6 quarts in it depends some times but check the dipstick when you are fillin it
Hoenes
03-28-2006 19:08:15
 Re: WD-45 oil change in reply to Dairy Farmer, 03-27-2006 18:09:34
I was told not to use car oil [multi-viscosity oil] in tractor engines. I use straight 30 weight.
BT in Minnesota
04-01-2006 13:47:34
 Re: WD-45 oil change in reply to Hoenes, 03-28-2006 19:08:15
That may have been so when the WD45 was built, but the oils we have today are much better, and I would have no reserves as to using a modern multi-grade oil in a WD45. I prefer the detergent oil to the non-detergent oil myself; and that alone was the reason many old timers stuck with the straight weights.. non-detergent oil was usually available only as a straight weight oil..There is nothing that could possibly be harmed by using a multi-grade oil in a WD45..
