1950 IB carb fine tunning.
Chances R
03-25-2006 17:24:05
third party image
What do you pros look for when adjusting a carb on the B with high rpm adjustment. Please give me your thoughts on.
1 Setting the throttle arm stop screw.
2 Setting idle adjustment.
3 Setting high rpm adjustment.
Dont get me wrong my tractor has a rebuilt carb and is running great but I would like this tractor to run as well as possible so it can be very competitive in tractor driving compitition. Thank you Charlie
old
03-25-2006 20:46:37
 Re: 1950 IB carb fine tunning. in reply to Chances R, 03-25-2006 17:24:05
Thats one of those thing you have to play with an have a good ear or RPM meter to figure out. You want it to idle down as low as you can but also when you put the gas to it spin up well. It takes some play with it to get it to do so and if every thing isn't just right you can have problems doing so. Its a case of play with it and then play some more
