Position control on D15?
Stumpy
03-23-2006 15:52:01
Hey Guys,
I have been playing with my new to me D15. It is a sweet running tractor! I do have a couple of questions though.
How do I get position control with the lift? I have the "traction boost" lever and the lift control lever, do they need to be set any special way? Next, I sprung a leak! This is what prompted the questions. The remote on the back of the tractor is supplied by a hyd hose that originates under the gas tank behind a sheet metal panel. I was using the loader and had the hitch in the up position, Inoticed oil drops on my driveway and investigated. A fitting had cracked and was spraying a very fine mist of oil onto the left fender. When I dropped the lift it quit, so is that remote only used in conjuction with the lift?
Thanks for your time
Stumpy
JMS/MN
03-25-2006 17:27:30
 Re: Position control on D15? in reply to Stumpy, 03-23-2006 15:52:01
I'm going back to the recommendation of getting the operator manual. For the D17 there are over 2 pages describing your options- not so much in adjustments, but equipment available to do what you need to. Selector valve, transport valve, single spool valve, triple spool valve.
JMS/MN
03-24-2006 08:17:08
The operator manual has details on how to set the hudraulic system for various uses, including position control.
Butch(OH)
03-24-2006 08:14:51
Is no position control in the sence that most 3 point hitch equipped tractors have. The best you can get is slow creep up or slow creep down. The traction booster lever (top one) should be all the way down. With the tractor sitting still and a load on the lift arms find the spot with the least amount of creep and mark the quadrant for referance. The remote line is simply tee"d into the line supplying the lift arms so a leak in either effects the other.
JMS/MN
03-24-2006 08:19:18
 Re: Position control on D15? in reply to Butch(OH), 03-24-2006 08:14:51
Oops- I guess I was thinking of the WD system.
