'48 WD-45
mj
03-21-2006 09:17:22
Need to know the sparkplug wiring on magneto ignition trasctor.
old
03-21-2006 09:42:39
 Re: '48 WD-45 in reply to mj, 03-21-2006 09:17:22
First off if its a 1948 its a WD not a WD-45. Are you asking what the fireing order is?? If so its 1,2,4,3
mj
03-21-2006 18:39:32
 Re: '48 WD-45 in reply to old, 03-21-2006 09:42:39
Thanks, old. I'm a Case man myself but was inquiring for another feller. He says he knows the firing order but wants the routing of the wires from the plugs to the specific terminal on the mag. I told him to set the engine on TDC, set number one on the mag and go from there but he doesn't seem to 'savvy'! Oh well, maybe I'll drive over there and check it out.
Texas Denny
03-22-2006 06:08:46
 Re: '48 WD-45 in reply to mj, 03-21-2006 18:39:32
As you may know, the mag can be set up with #1 in any of four positions. Allis (from the factory) set it up with #1 being the top terminal closest to the block. The manuals all suggest this as well. So if the past mechanic(s) did as the manual suggests, that will be #1. But I would recommend finding top dead center on the #1 cylinder on the compression stroke and then verifying where the rotor is. You can't afford to assume that it is as Allis intended.
mj
03-22-2006 20:13:54
 Re: '48 WD-45 in reply to Texas Denny, 03-22-2006 06:08:46
Thank you, sir! I'll pass the info along. :-)
