Still a stuck engine-WD
kwahl1
03-20-2006 20:24:48
See earlier post. You guys are great. Hadn"t had much time to get to it but did try the trick of jacking up the rear, putting it in 4th gear and trying to spin it loose. No luck yet. Used Liquid wrench. With the pan off, I can look up and I can see rust at the base of the #1 piston. Hmm? In front where the hand crank would go, is mounted a dome shaped hydralic pump with hoses in and out. I took it off and I can get a pipe wrench on the shaft, and turn, but it only turns a chain driven type gear below the radiator and does not turn the crankshaft. I haven"t taken the radiator off yet to see what that chain gear thing is. I"d just like to free the pistons by turning the shaft. Any more ideas are greatly appreciated.
dej(JED)
03-22-2006 12:05:07
 Re: Still a stuck engine-WD in reply to kwahl1, 03-20-2006 20:24:48
I have had a couple of easy ones to get freed up, but not most. Pull the head, cut a piece oak
log and wack on it with a sledge. It might break loose. I have had some that I busted the pistons out of. Good luck, you will need it.
D17JIM
03-21-2006 09:47:16
This may sound crazy but It worked. I had a 44MH that had a stuck piston and after soaking and pulling and prying, an older Ag Teacher told me that if the piston was close to the top to remove the head and fill the cylinder with grease. Ya grease. He then made a fitting to adapt a grease zerk to the spark plug hole and we put the head back on and started pumping with a hand held grease gun. The gun handle got reallll tight and the next pump broke her loose!!!! clened it up honed the cylinder and it ran like a champ. Would not have beleived it if I had not done it.
old
03-20-2006 22:01:11
Fill all the cylinders with tranny fliud and then just kick bac and let it do its thing. Top it off every few day.
IBOrange
03-20-2006 21:19:29
A stuck engine takes a lot of time to undo. The last one I had, I sprayed PB catalyst in each cylinder, let set a week, took out the starter, with a pry bar, turned the flywheel backwards. Just one tooth is all it took, then moved it forward. Followed same procedure for several days, when it broke loose, used Marvel Mystery oil in the cylinders. Rotated it many times, drained that out and added some 30w motor oil to the cylinders, rotate again. replaced starter, added a qt of motor oil to the full gas tank. Hit the starter and she fire off w/ a lot of smoke. good luck
Texas Denny
03-20-2006 20:31:55
The last one I unstuck took me 4 months. The last piston had to be pushed out in a hydraulic press. Some may come easy. Some are impossible. If the #1 is the only one showing rust, and the piston is at the top or near top of the revolution, You might try disconnecting the rod cap and turning the engine away from the cap. The other three might not be stuck. Having one cylinder much worse than the rest is a typical situation.
This is not a fast process in many cases.
