WD PTO?
Mike S
03-20-2006 15:21:52
Does the PTO run independently of the gear box? On my Jubilee, if I push in the clutch the PTO stops. Is that what happens on a WD or does it keep running? Do you think you could run a tiller with a WD or is the gearing not right for it? and it is 6 volts. is it positive ground like my Ford?
Craig Lysne
03-21-2006 19:35:19
 Re: WD PTO? in reply to Mike S, 03-20-2006 15:21:52
The PTO runs off the foot clutch. If you have the PTO running and you push the foot cluch in the PTO will stop.i think it should run a tiller just fine and the battery is negitive to ground. To engage the PTO you need to push the foot clutch in and pull the leaver.
LWD
03-20-2006 22:07:36
I use a ford 901,and it does a nice job with a tiller
Bill(Wis)
03-20-2006 19:46:05
You got all good info below. Now, my question would be, how much roto-tilling do you plan to do? If you're doing a lot of acres, why not plow, disc and drag it? If you're only doing a half acre or so, try the roto-tiller behind the WD. Use low gear and, if necessary, slip the hand clutch. You would never believe what those virtually indestructible multi-plate wet clutches will take without seeing it. We chopped 10-12 foot high corn for years with a '49 WD and slipped the clutch whenever we had to, which was a lot. I'll bet you could do that for years and never have to do anything more than remove a shim.
TRC
03-21-2006 05:34:23
 Re: WD PTO? in reply to Bill(Wis), 03-20-2006 19:46:05
Good points, Bill. You could slip that hand clutch a little and probably get by. Really, once the soil has been worked, the ground speed of the tractor might not be terribly fast the next time you go over it with the tiller. Still, slower ground speed would be better.
Tim
TRC
03-20-2006 17:52:59
The ground speed of the WD is too fast for a tiller. You need a tractor that has a very slow low gear; the WD ain't that type of tractor. The hand clutch will allow you to have the features of live power, but you gotta remember to use it. That's not the easiest of things to do when you're used to using the foot clutch on everything. Just a different animal. Tim
JMS/MN
03-20-2006 15:42:30
The hand clutch on the WD provides live- not independent- power to the pto and hydraulic system. Foot clutch stops both. Standard electical system is 6 volt, positive ground.
Mike S
03-20-2006 16:29:55
 Re: WD PTO? in reply to JMS/MN, 03-20-2006 15:42:30
Thanks for that bit of info. I guess if I want to do a tiller, I better look at one of the newer compacts like Kubota, Yanmar, etc.
