hydraulic lift system oil
s smith
03-16-2006 08:55:38
Have an AC D-10 (serial no. 9000s). Need to know what type of oil to add to the hydraulic lift system. My shop manual does not indicate, but does indicate that when replacing the pump to prime it with "20 weight oil" - so am assuming that is what I use to add to the system to bring it up to full? Can anyone help me out?
s smith
03-23-2006 03:15:38
 Re: hydraulic lift system oil in reply to s smith, 03-16-2006 08:55:38
Thanks for the info. I don't have an operators manual for my AC D10, just the shop manual. Will use your advice on the type of oil to add.
JMS/MN
03-17-2006 19:50:38
Lube recommendations are found in operator manuals, not shop manuals.
Kent of SW MO
03-17-2006 06:43:53
The Allis oil that replaced 20W was 821. I think you can use the Universal Hydraulic Oil. On a farm with many differing brand of tractors, Using the same hydraulic equipment the differing oils mixed anyway. You might have a mix of JD303, Allis 821, International now Case/International Hy-tran. My Allis combind uses Type A ATF.
Kent
souNdguy
03-16-2006 10:48:15
If it likes 20w stuff.. seems the common utf/hyguard/hytran/jd303/cnh-134d type ils should be pretty close. If it was a closed hyds 'only' system.. guess you could use an aw32.. etc..
I have hytran in the hyds on my allis g...
Soundguy
